跳转到主内容
Sony Xperia M4 aqua was released 2015, June. With a Size of 5.0 inches, it was operated in Android OS, v5.0.1. Sony Xperia m4 Aqua has internal of both 8 GB, 2 GB RAM/ 16 GB (E2306) And it has 13 MP Primary Camera and a 5MP Secondary Camera. This phone has a non-removable Li-Ion 2400 mAh battery.
37 个问题 查看全部
Phone stopped powering on... maybe a possible fix!
Okay... so i had a m4 aqua with no screen output, but it responds(let's refer as first phone). Recently i got a cheap m4 aqua that only needed to swap the battery so i did it and it worked for some time( let's refer as phone 2). I don't know why the phone 2 is not turning on anymore(something with power delivery i'm guessing). Now that i opened both phones to check differences i saw that there are some parts missing from the first phone that are on second(pics attached) maybe it's possible to somehow combine 2 into 1 and make 1 functional phone?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
on phone 1 there is one missing LCD Filter part, you dont need to take component on phone two and resolder it on phone one. just do the jumper to makes LCD on phone 1 works again..
i hope this helps
这个答案有帮助吗?
得分 0
2条评论:
So you are saying it's possible? How to do the jumper thingy?
完成的
i have done many cases like that.. just see on my instagram page @masterdogen_qualityrepair
完成的
添加一条评论
I have also same problem.. After pressing the power key.. Sony logo come then release the power key.. Mobile get shut down
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
igors riekstins 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 1,286
