跳转到主内容
加入维修社区 - 创建账户
产品发布于 2006 年,型号 #MID9742
Lost kyross entry passcode
Lost kudos passcode. Will reformat tablet override??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Yes it will remove pass
由完成的 分享
l. Pfaf9sI'm grateful you write but I still came get home button to bring up scroll menu screen.
由完成的 分享
添加一条评论
1个答案
最有帮助的答案
Nicole Turner, If you have forgotten pass code, reset procedure below will get your back into(unlock) tablet. .Info. found at androidtablets.net. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Master Reset Procedure.
Power the unit off. Press and hold the "Power Button" till the "Device Option menu appears.
Click "Power Off" and select "OK"
Once the unit has been turned off. Press and hold the "back" button(silver tone button) and "power" button simultaneously for eight seconds.
When the Android Icon and warning triangle appear , press the "back" button )silver tone button) once.
The Android recovery screen will appear. The "Home/Menu" button will allow you to scroll up and down.
Press the Home/Menu button to scroll to "Wipe Data/Factory Reset" Then press the "back" button
On the next screen Scroll to "yes-delete all user data" Press the "back" button.
On the next screen Choose "reboot system now" and Press the "back" button.
You will now be able to access the tablet.
这个答案有帮助吗?
得分 1
2条评论:
Will this work with kyros. Mic 9740
由完成的 分享
I'm sorry that's auto correct got me . It's suppose to be MID 9740 THA KS
由完成的 分享
添加一条评论
添加你的答案
Nicole Turner 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 22
总计 784
