跳转到主内容
加入维修社区 - 创建账户
Motorola 于 2015 年 10 月下旬发布了 Droid Turbo 2。型号为 XT1585。
What screwdriver does the inside take?
I have the iPhone screwdriver but that doesn't work
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
that's a pretty vague question.
do you have a picture of what youre talking about?
完成的
添加一条评论
1个答案
最有帮助的答案
@turtlj ,Turtl Johnson, From the partial disassembly link below, these are the screw types mentioned.
17 screws from the board using a T3 bit on your screw driver. Or, use a T4 bit if the screw is slightly stripped.
4 silver screws on the top and bottom are 4.0mm Phillips #00, and the 13 black screws around the sides are 3.0mm Phillips #00.
Using a T3 bit on your screw driver, remove the two 4.0mm screws from the metal bracket.
Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Motorola Droid Turbo 2 后置摄像头更换
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Turtl Johnson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 1,051
