跳转到主内容
Dymo LabelManager 160 is fast, compact and lightweight, making it easy to label just about anything, anywhere. Type quickly on the computer-style QWERTY keyboard, edit with one-touch fast-formatting keys and print for perfect, professional labels every time.
My display is frozen, how do I reset it?
My dymo label manager is stuck on the screen that you use to change the font and size. I've changed the batteries and tried plugging it in but it wont do anything except switch off and on but it just returns to the same screen. Is the a factory reset I can do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
To perform a factory reset:
Switch it off, then press and hold backspace button together with '9' and on/off button
这个答案有帮助吗?
得分 4
5条评论:
Mine will not reset I turn it off. the press backspace '9' and power button. Just turns back on. No Reset.
完成的
Mine is the same. Have you found a way to reset which works? Thanks
完成的
I have experienced the same issue it will not reset, and keeps going to the same screen, has anyone got a solution?
完成的
Tried a power refresh and it still returns to the same screen, no reset works, is there not a manual reset I can do?
完成的
My Dymo 160 would not do a reset.
1. I took out the 6 screws and removed the keypad from the machine.
2. I cleaned all the gold key points with a alcohol wipe.
3. Cleaned the back of the buttons with the wipe.
4. Dried both parts off with a tissue.
5. Put it all back together.
6. Boot it back up using backspace/9/on&off
7. Confirm the Erase
完成的
添加一条评论
Hi @tim21354
Try a power refresh and check if that resolves the problem.
Switch off the device (if it is on) and then remove the batteries from the device.
Here's the ifixit Dymo LabelManager 160 Batteries Replacement guide that may help.
Press and hold the power button for 30 seconds and then release.
Reinsert the batteries, reassemble the device and check if it turns on OK
这个答案有帮助吗?
得分 0
1条评论:
This still has not resolved the issue, it still returns to the same screen
完成的
添加一条评论
@tim21354 for the LabelManager 160 do a complete reset.
Turn the printer off
important - REMOVE THE TAPE from the printer
Now press and hold "Backspace" button the "9" and the "On/Off" button at the same time
You may need to try this a couple of times due to the awkwardness of pushing those buttons or try the ERASE option by
REMOVE THE TAPE from the printer. then press "9" and "Backspace" simultaneously, THEN the Power button.
That should restore your font options.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
alice 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 67
总计 6,076
