跳转到主内容
加入维修社区 - 创建账户
任天堂于 2011 年 2 月发布的首款 3DS 掌上设备,型号为 CTR-001。
3ds top screen not working
My top screen is black and the bottom touch screen works does anyone know why I am having this problem with my 3ds?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 8
添加一条评论
4个答案
最有帮助的答案
@colhot ,colette , Maybe there's a problem with the cable connection to the top screen that's causing this, as the hinge moves it may have damaged cable/wire or loosened connection. Below 1st link is to disassembly guide for upper display to enable you to get inside device to check and clean all connections/reseat them and check for damage. Clean all the connections with a Qtip dampened with 90%+ Isopropyl Alcohol and reseat for good connection. If all connections,wire,etc look good the LCD likely faulty. If needed the 2nd link is for more guides for your device. The 3rd link is a replacement lower LCD display if needed which you can also do a search on for better pricing perhaps. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
任天堂3DS上屏更换
Nintendo 3DS
Nintendo 3DS Upper LCD
Replace a broken or damaged LCD in the upper half of your Nintendo 3DS portable game console with this part.图片
产品
$29.99
这个答案有帮助吗?
得分 5
1条评论:
I followed David Godson's guide for replacing abxy buttons but now the top screen won't work...
Please help.
完成的
添加一条评论
I think it is a good question
这个答案有帮助吗?
得分 2
添加一条评论
Is this expensive to fix??? I want my parents to fix it for my 13th b day!
这个答案有帮助吗?
得分 1
添加一条评论
my top screen is black and i can’t see what am i doing when i play a game because my top screen dose not work do i need to replace it are something.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
colette 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 21
过去 30 天: 81
总计 27,379
