跳转到主内容
加入维修社区 - 创建账户
于 2014 年 10 月 16 日发布,型号为 A1347 和 EMC 2840。
Adding SSD Drive to PCIe model
Can anyone assist with what parts I would need to add an SSD to a Mac Mini 2014 that came with a PCIe 512 GB drive?
I'd like to make it a dual drive setup, but can't confirm what part is needed to do so. Any help would be greatly appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
me to i would like to recieve and so place a PCIE drive on my mac mini late 2014. can you send me the link for buying that item?
bst regards
由完成的
@yannick17 - Review my answer for the details
由完成的
添加一条评论
2个答案
已选择的解决方案
If you already have the PCIe SSD then you're adding a SATA drive (either a HD or a SSD) You'll need the to follow this IFIXIT guide Mac mini Late 2014 硬盘线缆更换 and need this part & tool kit: Mac mini Dual Drive Kit. Be careful here! The size of the drive needs to physically fit (12 mm is about it).
If you have a SATA HD already then you'll want this: either the drive carrier with the SSD cable mounted Hard Drive Carrier w/ SSD Flex Cable - Apple P/N 076-00040 or the cable its self Cable, SSD Flex - Apple P/N 076-00018
Here's the IFIXIT guides:
All the hardware needed to a second hard drive to your 2011 or 2012 Mac mini.图片
产品
$29.99
Mac mini Late 2014 PCIe SSD 线缆图片
指南
Mac mini Late 2014 PCIe SSD 线缆更换
难度:
中等
15 - 20 minutes
Mac mini Late 2014 硬盘线缆图片
指南
难度:
中等
1 hour
Mac mini Late 2014 硬盘托架图片
指南
Mac mini Late 2014 硬盘托架更换
难度:
中等
这个答案有帮助吗?
得分 1
2条评论:
Dan, If I already have a fusion drive in there will I need any of these replacement parts, or can I just substitute the respective PCIe and 2.5 inch drives for the existing ones?
由完成的
You'll need to make a full backup before doing anything.
First step is to break the Fusion Drive following this How to split up a Fusion Drive.
And yes, all of the needed hardware sans the replacement drive/s is present.
But before you jump what is your goals here?
由完成的
添加一条评论
When adding a HDD to a PCIe SSD only 2014 mini, which HDD cable do you need? (1) the mini dual drive cable, or (2) the upper SATA cable?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
tomtcs 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 19
过去 30 天: 39
总计 1,995
