跳转到主内容
于 2014 年 10 月 16 日发布,型号为 A1347 和 EMC 2840。
Setting up Fusion Drive on Mac Mini Late 2014
I am trying to find a good guide and parts I need to buy to modify my current 5400rpm 1TB HDD and add a SSD to make a Fusion Drive.
All I can find is this: Mac mini Late 2014
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
Our guides are structured from a hardware perspective which can be a bit confusing when you are trying to setup a dual drive configuration like a Fusion Drive.
So you have a HDD drive and now you need to add in the SSD using this Flex cable for a solid state drive (SSD) for the Mac Mini following this guide Mac mini Late 2014 PCIe SSD Cable Replacement then you need the SSD [关联产品丢失或禁用: IF123-123] you only need the smaller 240 GB drive.
At this point you have the needed hardware and if you’ve got it all installed you’ll need to run Disk Utility to format the SSD and lastly convert your SSD & HDD into a Fusion Drive following this How to make your own Fusion Drive
这个答案有帮助吗?
得分 1
2条评论:
your guide says compatible to the older Mac mini 2011/2012 not 2014
完成的
I just checked all of the hardware posts all state clearly 2014 so I have no idea what you are reading. The Fusion Drive setup guide (2012) is older than your system which is why it doesn't state 2014 as your system came out afterwards.
I can tell you I've setup a good dozen without any problems.
完成的
添加一条评论
Yes, you can. And I just did mine and the speed (and size) of the fusion drive is awesome. Here are the brief steps:
  1. You will need the flex cable to connect the SSD to your mini motherboard. You can get it from Ebay or Taobao. Like this one (https://www.ebay.com/itm/PCI-E-flex-cabl...) or choose one that has SSD come with it.
  2. Open the mac mini’s back using special TR-6 screw driver. Note, not regular T-6 screw driver. You can buy one from Amazon (https://www.amazon.com/gp/product/B01BG8...)
  3. Install the SSD drive with flex cable, You will also need a regular screw to secure the SSD on the top side. I found one from another laptop’s internal wifi module.
  4. Boot up the mac and check the hardware, you will see two hard drives, one for the HDD and another for the SSD.
  5. Follow apple’s instructions to merge the two drives into a fusion drive. Note that you have to wipe the system so better backup. https://support.apple.com/en-us/HT207584
  6. For me, I put in a 256 SSD and get a total of 1.25TB fusion drive. Enjoy the speed (and capacity)!
这个答案有帮助吗?
得分 1
添加一条评论
My mini came with just a 256GB SSD. I’d like to add 1TB HDD. And make it a Fusion setup. Does the 2014 SSD-only version have the HDD connector already?
这个答案有帮助吗?
得分 0
1条评论:
The logic board has the needed hookup. You'll need the cable Mac mini A1347 (Mid 2011-Late 2014) Upper SATA Cable and here's the guide you'll need to follow Mac mini A1347 (Mid 2011-Late 2014) Upper SATA Cable
完成的
添加一条评论
添加你的答案
fredy.soussou 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 36
总计 6,067
