跳转到主内容
The iRobot Roomba 770 is a cordless, autonomous vacuum that will clean your floor without supervision.
The brushes will not rotate
The brushes will not rotate, how I can fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
What is the thickness of your carpet? And have you tried it on multiple surfaces?
完成的
添加一条评论
1个答案
Sounds like they are probably jammed. Look at them and look near the edges for hair and other objects that are entangled within the brushes. If you see anything, a seam ripper or letter opener is the best and easiest option but if you dont have any, scissors will work as well. If you see anything, use one of the tools above to remove it. Once its all removed test it. If it still isnt working theres probably a bigger issue and you can contact Roomba and see if they can fix it for you.
Hope this helps and good luck fixing!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lior 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 8
总计 149
