跳转到主内容
加入维修社区 - 创建账户
Nintendo DS 的后继机种 Nintendo DS Lite 于2006年发布。这款设备的拆解和维修十分简单。
mine won't stay on past lifting the lid halfway - just shuts off.
1. toggle side switch
2. begin raising lid
3. device starts and game is accessible and playable until lid reaches halfway point
4. at halfway point (approx 90 degree angle to base), devices shuts off
Using toggle side switch produces a quick flash in the lower screen.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@thepogan , Kayla , It could be a bad connection on one of the display's ribbon cables or a bad cable (probably the upper cable connection or cable damaged). Below are links to guides that show how to partially disassemble the DS so you can check the cables for damage and reseat them to make good connection if not damaged. Good luck.
Nintendo DS Lite Upper LCD Replacement
Nintendo DS Lite Lower LCD Replacement
Nintendo DS Lite Lower LCD图片
指南
难度:
中等
30 minutes - 1 hour
Nintendo DS Lite Upper LCD图片
指南
难度:
困难
2 - 3 hours
这个答案有帮助吗?
得分 2
3条评论:
L Pfaff, I've uploaded an image. Please confirm this cable is broken. Sorry it's taken so long to get back to you. https://imagebin.ca/v/3NooMlfyzkSh
完成的
Kayla, The pic. was pretty blurry but cable does look damaged and is probably the issue.
完成的
L Pfaff, Thanks.
完成的
添加一条评论
添加你的答案
Kayla 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 90
