跳转到主内容
加入维修社区 - 创建账户
Nintendo DS Lite Lower LCD Replacement
你所需要的
  1. Nintendo DS Lite Lower LCD Replacement, Battery: 步骤 1 中的图像 1,2 Nintendo DS Lite Lower LCD Replacement, Battery: 步骤 1 中的图像 2,2
    • Unscrew the Phillips screw securing the battery cover to the lower case.
    • The screw remains captive to the battery cover.
    • Pry the battery cover upward with a spudger or fingernail, and lift out of the lower case.
    添加评论
  2. Nintendo DS Lite Lower LCD Replacement: 步骤 2 中的图像 1,1
    • Wedge the edge of a spudger in between the side of the battery and the lower case housing and pry upward to dislodge the battery.
    • Remove the battery from the DS Lite.
    询问修复机器人
    添加评论
  3. Nintendo DS Lite Lower LCD Replacement, Lower Case: 步骤 3 中的图像 1,2 Nintendo DS Lite Lower LCD Replacement, Lower Case: 步骤 3 中的图像 2,2
    • Use the tip of a spudger to pry both rubber feet off the DS Lite.
    询问修复机器人
    添加评论
  4. Nintendo DS Lite Lower LCD Replacement: 步骤 4 中的图像 1,1
    • Remove the following screws securing the lower case to the body of the DS Lite:
    • Two 4.3 mm gold Phillips screws
    • One 3.9 mm black Tri-point screw
    • One 3.3 mm silver Phillips screw
    • Three 5.5 mm silver Tri-point screws
    添加评论
  5. Nintendo DS Lite Lower LCD Replacement: 步骤 5 中的图像 1,3 Nintendo DS Lite Lower LCD Replacement: 步骤 5 中的图像 2,3 Nintendo DS Lite Lower LCD Replacement: 步骤 5 中的图像 3,3
    • Remove the cover from the Game Pak slot before continuing.
    • Insert the edge of a spudger in between the lower and upper case near the top right corner of the DS Lite.
    • Carefully run the spudger along the right edge of the DS Lite, creating an opening in the process.
    • Continue running the spudger along the backside of the DS Lite until the majority of the lower case has been separated from the upper case.
    添加评论
  6. Nintendo DS Lite Lower LCD Replacement: 步骤 6 中的图像 1,1
    • Lift the lower case away from the rest of the DS Lite.
    • Pull carefully. Some units are sealed with adhesive, and pulling too hard can damage the power switch.
    • When re-assembling, make sure that power switch and volume sliders are properly aligned with the switches on the motherboard.
    添加评论
  7. Nintendo DS Lite Lower LCD Replacement, Trigger Buttons: 步骤 7 中的图像 1,2 Nintendo DS Lite Lower LCD Replacement, Trigger Buttons: 步骤 7 中的图像 2,2
    • Lift both trigger buttons out of the DS Lite.
    • The trigger buttons are held in very loosely by small metal pegs and springs. Don't lose track of these pieces.
    • The second picture shows the correct configuration of the trigger assembly for reassembly purposes.
    添加评论
  8. Nintendo DS Lite Lower LCD Replacement, Wi-Fi Board: 步骤 8 中的图像 1,1
    • Use the flat edge of a spudger to pry the Wi-Fi antenna connector straight up from its socket on the Wi-Fi board.
    添加评论
  9. Nintendo DS Lite Lower LCD Replacement: 步骤 9 中的图像 1,1
    • Use the flat edge of a spudger to pry the Wi-Fi board connector straight up from its socket on the motherboard.
    添加评论
  10. Nintendo DS Lite Lower LCD Replacement: 步骤 10 中的图像 1,1
    • Use the flat edge of a spudger to separate the right edge of the Wi-Fi board from the motherboard.
    • The Wi-Fi board is secured to the motherboard with a layer of adhesive.
    • Remove the Wi-Fi board from the DS Lite.
    添加评论
  11. Nintendo DS Lite Lower LCD Replacement, Motherboard: 步骤 11 中的图像 1,1
    • Use the flat edge of a spudger to pry the microphone connector straight up from its socket on the motherboard.
    询问修复机器人
    添加评论
  12. Nintendo DS Lite Lower LCD Replacement: 步骤 12 中的图像 1,3 Nintendo DS Lite Lower LCD Replacement: 步骤 12 中的图像 2,3 Nintendo DS Lite Lower LCD Replacement: 步骤 12 中的图像 3,3
    • In the following steps you must pull the antenna cable between the DS Lite game cartridge reader and motherboard. Pull slowly and stop when you feel resistance to avoid damaging the cable or motherboard.
    • Position the antenna cable with its connector facing up and away from the motherboard using a spudger to hold it down lightly in the gap between chips on the motherboard.
    • Slowly and carefully pull the antenna cable until the cable connector is under the DS Lite game cartridge reader.
    • Continue pulling the cable until the cable connector comes out from under the game cartridge reader on the right side.
    • When reassembling and attempting to feed the antenna cable back under the game cartridge reader, the cable may kink or become difficult to feed through. If so, try feeding a piece of thread through first; then, tie the thread to one end of the cable connector and pull it through, guiding it past any obstructions.
    添加评论
  13. Nintendo DS Lite Lower LCD Replacement: 步骤 13 中的图像 1,2 Nintendo DS Lite Lower LCD Replacement: 步骤 13 中的图像 2,2
    • Use your fingernail or the edge of a spudger to carefully flip up the touchscreen ribbon cable retaining flap.
    • Make sure you are flipping up the retaining flap, not the socket itself.
    • Use the tip of a spudger to pull the touchscreen ribbon cable straight out of its socket.
    • Do not lift the flap more than 90 degrees, or you will break it off.
    添加评论
  14. Nintendo DS Lite Lower LCD Replacement: 步骤 14 中的图像 1,1
    • Remove the two 3.4 mm Phillips screws securing the motherboard to the upper case.
    添加评论
  15. Nintendo DS Lite Lower LCD Replacement: 步骤 15 中的图像 1,1
    • Open the display enough to use your finger to push the front edge of the motherboard up and away from the upper case.
    • Do not try to remove the motherboard, as it is still connected to the upper display via the upper LCD ribbon cable.
    询问修复机器人
    添加评论
  16. Nintendo DS Lite Lower LCD Replacement: 步骤 16 中的图像 1,2 Nintendo DS Lite Lower LCD Replacement: 步骤 16 中的图像 2,2
    • Use your fingernail or the flat edge of a spudger to carefully flip up the upper LCD ribbon cable retaining flap.
    • Pull the motherboard away from the DS Lite to separate the upper LCD ribbon cable from its socket on the motherboard.
    • Remove the motherboard from the DS Lite.
    • Now you may open the retaining flap for the lower LCD screen in the same way and separate the lower LCD screen from the motherboard.
    添加评论
  17. Nintendo DS Lite Lower LCD Replacement, Lower LCD Assembly: 步骤 17 中的图像 1,2 Nintendo DS Lite Lower LCD Replacement, Lower LCD Assembly: 步骤 17 中的图像 2,2
    • Use your fingernail or the edge of a plastic opening tool to carefully flip up the lower LCD ribbon cable retaining flap.
    • Pull the lower LCD assembly straight away to separate the lower LCD ribbon cable from its socket on the motherboard.
    • Remove the lower LCD assembly from the motherboard.
    • When reinstalling lower LCD, ensure it has insulation on the back to prevent a short circuit with the motherboard.
    询问修复机器人
    添加评论
  18. Nintendo DS Lite Lower LCD Replacement, Lower LCD: 步骤 18 中的图像 1,2 Nintendo DS Lite Lower LCD Replacement, Lower LCD: 步骤 18 中的图像 2,2
    • Insert a plastic opening tool between the touchscreen and top right corner of the display.
    • Slide the opening tool down the right side of the display to free the edge of the touchscreen.
    询问修复机器人
    添加评论
  19. Nintendo DS Lite Lower LCD Replacement: 步骤 19 中的图像 1,2 Nintendo DS Lite Lower LCD Replacement: 步骤 19 中的图像 2,2
    • Continue sliding the plastic opening tool along the bottom and up the left edges of the LCD to separate the touchscreen from the LCD.
    询问修复机器人
    添加评论
  20. Nintendo DS Lite Lower LCD Replacement: 步骤 20 中的图像 1,2 Nintendo DS Lite Lower LCD Replacement: 步骤 20 中的图像 2,2
    • Lift the touchscreen away from the LCD.
    • LCD remains.
    • When replacing the LCD, ensure it has insulation on the back to prevent a short circuit with the motherboard. Electrical tape works fine.
    添加评论
结论
取消:我没有完成这个指南。
41等其他人完成本指南。
Matthew Newsom
于01/05/10注册
42,811 声望
创作了67篇指南
3指南评论
This guide recommends a Y1 Tri point scredriver. I bought one to try this repair and it's marginally too big :(
It does begin to bite the screw, then slips and fails. I daren't keep trying for fear of rounding the screws off, so
I'm going to try again with a Y0 and see how that goes.
Thomas Wood - 回复 分享
Following the instructions precisely and watching Steve from Tronicsfix's tutorial, I tried to fix my screen, but now it has no power.any solutions?
Lorla - 回复 分享
If I had to guess, I would assume that it is an issue with the way you attached the ribbon cable of the screen, but take that with a grain of salt, because im not positive 😶
Alexander - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 22
过去 7 天: 126
过去 30 天: 647
总计 61,921
