跳转到主内容
Is it the logic board or the Display
The backlight in my screen is not working. I have tried replacing the inverter. And I tried resetting the PRAM. I currently have my computer hooked up to my samsung television and it works fine. Does this mean that the logic board is fine and the problem is in the display? Is there other tests I can do to be sure before buying new parts?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
已选择的解决方案
The problem is isolated to the display subsystem, but do you see a faint image, or is the screen completely dark? If you see a faint image, you most likely need to replace the inverter cable (which goes bad infinitely more often than the inverter itself). If that doesn't do it, then the screen itself is the issue. You've proven the GPU works by successfully using an external display.
I don't agree with the "backlight is definitely powered from the video processor" statement...the GPU doesn't have a lot to do with the backlight...it's the screen electronics, inverter, and inverter cable that light the screen, and when any of those are bad, you'll often see a faint image with no backlight. In this situation, the GPU is working fine and doing it's job, providing the image, but the backlight is not its problem.
There are cases where a logic board is bad and prevents a backlight from working (even when the screen, inverter, and inverter cable are good), but I don't believe those cases are specifically related to the GPU...I think this situation has more to do with the logic board failing to provide power to the inverter, and, again, I don't believe the GPU has any part of that.
这个答案有帮助吗?
得分 2
2条评论:
there is a faint image simply no backlight. I tried replacing the inverter; assuming that the inverter and associated cables are good, you would advise a replacement screen???
完成的
First I'd recommend replacing the inverter cable. Like I mentioned, the inverter cable often gets crimped and is FAR more often the problem than the inverter itself, and it's a lot cheaper than a screen obviously, so it's a better place to start. If that doesn't work, then all you can do is replace the screen.
完成的
添加一条评论
最有帮助的答案
You are correct. The video processor on the logic board is good. Your problem is isolated to the display.
这个答案有帮助吗?
得分 3
2条评论:
A solid answer +
完成的
So the backlight is definitely powered from the video processor? Should have been my question all along...
完成的
添加一条评论
Hello, I just read this article and I am having the same problem. The problem all started with the screen flicker with the moving of the screen up and down. I tried changing the inverter, the inverter cable (the one with the negative ground loop...combined with the isight cable), changed the display data cable...After I did all this...actuallly now there's no more flicker...the screen just has the faint image...should i also try changing the inverter cable on the other side (pink and white one)?
这个答案有帮助吗?
得分 0
1条评论:
Hi there, you should really ask this as a new question. right now it appears as if you are answering an older question. Check on the right hand side of this page and you will find a link "Ask a Question" it's not hard to do but it makes sure that people see you are asking. Good Luck
完成的
添加一条评论
添加你的答案
Grant 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,644
