跳转到主内容
Repair and disassembly guides for Sony DVD players.
Wrong colours from DVD Disc's .
DVD loads, but picture quality has a pink cast over everything.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Hi,
What is the model number of the player?
What connection type are you using between the DVD player and the TV, HDMI, Component video (Red/Blue/Green - Red/White) composite video (Yellow/Red/White) etc.?
Have you tried using a different input or input type on the TV?
Have you tried a different DVD disc?
Does the TV have a 'normal' picture when viewing from a different signal source e.g. antenna or a 'box' of some type?
完成的
The old LG Blu Ray did not work with my LG smart TV. It was magenta so I hooked it back to my old VIZIO and sure enough that worked no issue. I think the old Blu Ray is simply outdated. And to be honest, who buys dvd anymore… I just wanted to get it to work so I can watch an old classic movie that is not available on streaming.
完成的
@elaineleeesq
What are the model numbers of the TV and the BluRay player?
完成的
添加一条评论
1个答案
已选择的解决方案
@frizbee ,Frances, Usually this would be caused by either not having the cables connected properly, or a bad cable, recheck your hook up and or try another set of cables. A pink picture often means the cable is either not inserted all the way, or possibly a bad cable.
One other possibility, the set up on either the TV or DVD is incorrect. Your sending one type of picture, and the TV is expecting something different and may not accept that format, try different disc with compatible format. Check the settings on your TV for right component. Also if you have never done so, run a DVD lazer cleaner through the DVD to clean the lazer, they can be bought at most electronics or big box stores as seen in the second link below also a forum talks of your issue in the first link. Good luck.
https://answers.yahoo.com/question/index...
https://www.walmart.com/ip/Memorex-32020...
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Frances Gavin 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 30
总计 3,929
