Tv remote volume is not going up or down
I have a 48" sanyo tv flat screen and the volume will not go up or donw i have to get really close to it for the volume to work like the remote is touching the bottom of the TV for the volume to go up and down and it should not be doing that.
2条评论
Mines is stuck on volume down ? Somebody help
由 mr.thomasblack3 完成的
@mr.thomasblack3 ,
What is the model number of the TV?
Try removing the batteries from the remote control unit and then using the TV controls (usually on the side or below the screen if it has them) to raise or lower the volume and see if this works.
If it does then check that the remote Vol. Down button is not stuck etc. Did the remote get wet at all?
由 jayeff 完成的
