跳转到主内容
The LeapFrog LeapPad Platinum 31565 combines a 7’’ high-resolution, multi-touch screen with a powerful quad-core processor. It is the latest model in LeapFrog’s line of learning tablets.
19 个问题 查看全部
How do I get the power button working on the leap pad ultra?
My sons leap pad the on and off button will not work , where can I get it fixed .?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Annalise Martin, Find below a tear down guide link, that could aid you getting inside the device to clean the button and connections to possibly get it working again. Replacement button may be hard to find. Remove/clean around the button and connections with a Q-tip/small brush dampened with 90% Isopropyl Alcohol to remove all grime/dust/corrosion, then try device. If not wanting to try repair, you can contact leapfrog support at the last link below for repair facility or take it into a local computer repair shop have them take a look, diagnose and estimate repair. Good luck.
LeapFrog LeapPad Ultra Repair Motherboard Replacement
http://www.leapfrog.com/en-ca/support/pr...
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Annalise Martin 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 9
总计 1,476
