跳转到主内容
加入维修社区 - 创建账户
第三代 C/K 皮卡车的维修指南和技术支持。
Automatic transmission downshifting problem
Shifts through the gears just fine, but when you let off the accelerator and it downshifts it makes a loud noise and the rear wheels tries to lockup. Sounds like gears grinding. Jacked up the back of the truck, and the axles spin free as can be. Only does it on downshifting.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
@wlw7241970 , William, Do you mean you are down shifting it manually or is it down shifting this way when in drive? Any recent work done,etc.
由完成的
添加一条评论
1个答案
已选择的解决方案
@wlw7241970 ,William, Check the transmission fluid level and condition, if low fill to correct level. If fluid is dark or smell burnt, change the fluid and filter and try. Have checked for any diagnostic codes that could lead to the fault. I believe it is usaully associated with the hydraulics and there are a few areas to look at possible loose/broke TV cable, the servo unit (a hydraulically applied piston) could be sticking, bad accumulator, pressure control solenoid, check balls sticking,dirty valve body, etc,etc.. You can check some of the stuff out your self, a lot should be checked out by a good tranny technician, I believe they just have to pull the pan to check.
Some of the auto parts suppliers offer free code reading like Pepboys, Nappa, Advanced auto parts,etc and some of the guys are very knowledgeable and may have seen the issue often and put you on the right track. Good luck.
这个答案有帮助吗?
得分 2
1条评论:
There is a shifter control modglar. On the out side of the trany. It basically tells the coumpter what gear its in. Could look there.
由完成的
添加一条评论
添加你的答案
William Wilson 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 36
总计 870
