How can I repair gouges in an ABS plastic kayak?
Bought a demo kayak with a few deep gouges. What materials do I need to repair them and what procedure should I follow?
Barb Wiginton , If not too deep, they can be sanded out starting with a medium wet sand paper working through to a very fine paper and finish by polishing. A headlight restoration kit can work well in removing scratches and can be inexpensive. See links below for more info. Good luck.
http://paddling.about.com/od/kayaks/fl/H...
这个答案有帮助吗?
Bill, will this work on thermoformed boats as well as the rotomolded type you worked on, I believe the thermoformed boats are an abs material. It is quite a bit thinner than rotomold best inflatable kayaks, but lighter and some what similar in strength, but would suffer a bit more in rock gardening.
Just wondering if the tarp material would stick, and be a good keel reinforcer.
any info would be helpful, Thx!
P.S. This repair looks easy and strong! Very cool!
这个答案有帮助吗?
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 45
总计 2,659
