跳转到主内容
Repair guides and support for the EOS 70D, a DSLR camera released by Canon in 2013. This camera can be identified by the model number DS126411.
replace the mode dial on canon 70d
how do I remove the mode dial on a Canon 70d ??
I have a replacement.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
5条评论
Hi, did you manage to find out how to replace it? Having problems with mine, and have just ordered a replacement.
完成的
No, unfortunately I haven't replaced it. I found a posting on the net from a guy who enquired at Canon and was told that a strip-down costing a couple of hundred Dollars was neccessary.
Mine's is stuck on manual, so I've just been working with that.
完成的
Have done some research and have gotten in contact with a guy that repairs cameras. He told me I would have to strip off the casing before I can replace the dial (I think it's held on by a screw from the inside). Will be attempting the tear down when my replacement dial arrives. Will tell you how it goes.
完成的
Alexander,
I was quoted 248.00 for what might be a simple task. Where can I buy the mode dial? Have you actually accomplished this repair yet? If so, I'd like to know if maybe it was not so easy or worth the cost I was quoted.
Joanna
完成的
Alma,
Did you find a way to get that mode dial repaired?
Joanna
完成的
添加一条评论
2个答案
最有帮助的答案
this post is a year old, but for those who are still looking for an answer on how to replace the dial mode on the 70d, or any canon dslr for that matter, you might want to see this video https://youtu.be/rpE7Co3dfgo
这个答案有帮助吗?
得分 1
1条评论:
thank you!!!!
完成的
添加一条评论
My camera is ded no power
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alma Kohl 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 33
总计 3,389
