跳转到主内容
加入维修社区 - 创建账户
2014 年发布的 RCA 7 英寸平板电脑(型号 RCT6773W22)的维修与故障排除指南。
cannot reset my tablet to factory default
I forgot my pin and even after resetting the tablet to factory default, the system is still asking for my email and password. It will not take my credential, even though it is correct.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 103
45条评论
Last step : set up as new device. Do not restore from saved info. I just did all of your steps and was a complete success. Thank you!!!
由完成的
I have done this like 6 times and it still won't work
由完成的
My daughter put an emoji pattern on hers and can't remember it
由完成的
Am same issues can't reset mine
由完成的
Ok ive tried to reset and it's not working my son a password but he forgot it now we can't even get in we've tried to reset password but can't. It's asking for a usb I but my usb but it's saying there's an error. Can anyone help me ?
由完成的
显示更多的40条评论
添加一条评论
13个答案
已选择的解决方案
@zahrahoda, Zahra Hoda , Make sure your device is charged before attempting reset and then powered off. Here are the instructions from the 1st link at the bottom, telling how to factory reset your device properly, link #2 is a video showing procedure. You can try this, hopefully it will solve your issue. Good luck.
Follow the detailed instructions below on how to completely reset your RCA Android 7 Voyager (RCT6773W22) tablet.
Step 1. With your tablet off, press and hold the volume up (+) button and power button until you see the RCA splash screen with Nipper and Chipper. Release both buttons to reveal the Android bot on his back with a caution symbol above him.
Step 2. A new screen will appear asking you to use your volume up/down keys to move and the power button to select.
Step 3. Use the volume down (-) button to highlight "wipe data/factory reset." Once highlighted, select using the power button.
Step 4. A new screen will appear asking you to confirm your selection. Use your volume down (-) button to highlight "Yes -- delete all user data." Press the power button to select once highlighted.
Step 5. Once the tablet is finished wiping data, you may press the power button to select "reboot system now." This will restart your tablet.
Step 6. The system will begin to reboot and once again display the RCA logo with Nipper and Chipper. The next "Welcome" screen will prompt you to select your language of choice. Scroll through the options using your finger and press start when finished. Congratulations, you have successfully reset your RCA 7 Voyager tablet.
http://wmp3.xyz/mp3/how-to-access-your-r...
https://www.youtube.com/watch?v=cp4IvkIA...
这个答案有帮助吗?
得分 73
59条评论:
Ive got throught the steps now lets see if these instructions have been a success. So far so good.
由完成的
I've done everything you said and my tablet still won't reset! It keeps asking me for my previous emails and passwords. The reason I want to reset is because I cannot remember my passwords! I want to use new passwords...UGH! I.ve done the steps you outline at least 6+X and nothing!!
由完成的
same here ugh.............!!!! what now?
由完成的
thank u soooooo much
由完成的
If you don't remember your password, create a new Gmail account on a different device. Sign in with the new account.
由完成的
显示更多的54条评论
添加一条评论
I learned from googling google that the gmail.com sign on will be removed if not used in the last nine months. The device may recognize the e-mail address but the server side of account is no longer there. I have a device that recognizes the email but won't sync with the server. The server side being deleted after nine months of not being used is deleted.
这个答案有帮助吗?
得分 9
5条评论:
Now what can I do, locked out email it was very odd account.
由完成的
I tried the power and volume button up and I did not see any icon the only thing that popped up was Viking 2 then it went to the login screen and and ask for a password to open it up I need help please
由完成的
I just tried it to and it did nonthin
由完成的
I just followed the instructions and it did not work
由完成的
i also tried to reset my mecer tablet, and i click on reset but it does nothing. and i cant remove the family link parental controls crap i put on when i got it for my son and since then i have removed deleted the family link app from my end, so its not linked on my side bu tshows linked on his side
由完成的
添加一条评论
If you don't remember your google password, the issue is not with your tablet. If you followed the steps above, your tablet is reset. You have to go to google.com & click forgot password. Once youve gotten your new password, then you can continue on with your tablet set up.
这个答案有帮助吗?
得分 4
6条评论:
No it still would not let me log on with the new password. It said that there was an unknown error.
由完成的
Nevermind I got a notification when trying to sign in after I had changed my password to wait 24 hours from last password change. I waited, logged in and it worked!!!
由完成的
ok ive been trying to reset my password but google wont do it
由完成的
Thanks it actually works
由完成的
it didn´t work for me
由完成的
显示更多的1条评论
添加一条评论
I found the solution under a different question.
Thank you wrightbethany18!! (I changed it a bit to explain clearer)
After doing the above factory reset, it wants you to sign in as the original owner. This is a workaround. Go to settings and add user. Here's how:
When it asks for Google email:
type a bunch of letters, press and hold to copy> choose assist> type or say settings> (in the settings menu) select add user> add YOUR Google email info.
It will take a few minutes to set up your new profile.
The original owner's profile is still there, but the tablet is completely usable. I haven't figured out how to remove it yet.
I hope this works for you too!!
这个答案有帮助吗?
得分 4
5条评论:
There is a good thing but I don't even have that option
由完成的
I did the factory reset and i typed in a bunch of letters held down the copy i clicked assist but where im confused at is after i press assist how do i get to setting? I dont have no voice command is that what you used was voice command? I still do not know how to get passed the original owners account? If anyone can help me please email me at deaconandsophia2015@gmail.com thanks!
由完成的
I am in same boat please email me how if u figure it out dawnbuterakos@yahoo.com
由完成的
Can some one email me on what to do I factory reset my RCA tablet because it was my moms she passed on so I knew the original email but not password so once I reset it it says cannot sign in on your accounts.google.com - I even changed the passwords to both google account so I’m stuck on the page can’t sign in and how do I get off that page I even did another factory reset- now what ?? HELP
由完成的
I tried to add a new user but it kept switching back to owner. does anyone know how to fix that?
由完成的
添加一条评论
None of these ideas work my tablet does not
这个答案有帮助吗?
得分 4
添加一条评论
I tried the add user but it says switching to new user and then it says switching to owner and it goes back and I'm stuck again… please someone help! Email me @jcjzj51980@gmail.com
这个答案有帮助吗?
得分 4
1条评论:
Try adding new user but " don't click setup account" and then go back to the lock screen / start screen and press the user icon in the top right corner and switch to the new user and setup from there, should work, I bypassed the Gmail login!
由完成的
添加一条评论
What do you do if you got a tablet from a yard sale and had to factory reset it? I don't have the previous owners Gmail info. Can I use my own Gmail info?
这个答案有帮助吗?
得分 2
5条评论:
Did you ever figure out how to get around owner info? I have the same problem
由完成的
Me too need help
由完成的
If u figured it out please email dawnbuterakos@yahoo.com thank u in advance
由完成的
How do I get pass the page I’m stuck on saying that ,can’t sign in to accounts.google.com-I even factory reset 3 times and changed my passwords and still can’t get off that page I’m just stuck there with that darn message when I know my info is correct
由完成的
I have a Maven pro tablet rct6213w87m bought this off swap in sell no the original owner will not text me back her email and I can't get into it does anybody know how
由完成的
添加一条评论
Nothing worked sorry.
这个答案有帮助吗?
得分 2
1条评论:
Just in case it's not obvious, there is nothing wrong with your tablets. There's a pattern here. Not the best of tablets,but when they work they work %#*@ well. This applies to most android tablets and phones. The tablet KNOWS is being reset. Its assuming it was lifted from its previous master. It was stolen. Since it knows you'll try all the things listed here, and there are no thieves here are they ? Try this, if you connected to the web assume your time is set. If you didn't the internal clock will go from where it stopped. Leave the %#*@ machine alone, but on for 3 days or so. If you didn't at 1st use the correctassumes grabber and shuts down its higher functions. It will reset but as I've said it will take a few days and basically give up do as its told. Two things never open the case. The safeguards will disable the device permanently. Never try and be clever by cutting or unplugging the battery. It can tell a suddenly missing B+ from a gradually dying Vcc
由完成的
添加一条评论
I just bought my tablet and it wont go pass the voyager 3 loading screen. What do i do?
这个答案有帮助吗?
得分 1
1条评论:
Hello. Who sold you this tablet? If it isn't going pass the Voyager screen, ask for a refund and buy a new one.
由完成的
添加一条评论
I got problem with my polaroid tab ptab7xc got it in yard sale forgot the passcode.. it will not do a hard reset. Please help Thanks
这个答案有帮助吗?
得分 1
1条评论:
I factory reset my tablet and put my email in and now it's saying can't connect to Google.. please help
由完成的
添加一条评论
I want to reset completely and asks for last email synced to device but I want to change settings for my daughter so she isn't stuck with YouTube kids and I cant figure it
这个答案有帮助吗?
得分 1
添加一条评论
I need to reset my tablet but it won’t let me and I’ve done everything it said to do and it still asked for the email n password that was used for this Device
这个答案有帮助吗?
得分 1
添加一条评论
What do i do it says there is no command and i don´t have a sd card what should i do
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Zahra Hoda 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 18
过去 30 天: 61
总计 247,858
