跳转到主内容
加入维修社区 - 创建账户
针对第 5 代 Honda Accord 双门轿跑车、轿车和旅行车的维修指南与支持。
cannot find any radio codes
i have a older Honda Accord [1996] the battery has been disconnected. cannot find any radio codes
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
You can get a radio code here: https://radiocodevault.com/honda
完成的
please help me the codes
完成的
添加一条评论
5个答案
已选择的解决方案
Donny Armstrong , Remove radio at least partially so you can get the serial #, normally on a white tag. Write down the serial # or take a pic., now with your ownership in hand and serial # of radio you can drive to the Honda dealer, provide proof of ownership, give them the numbers, and get your code. You can also contact Honda at links below and hopefully they can email you a code if given all required info.. 1st link shows how to remove radio, 2nd and 3rd link is where you can contact Honda. Good luck.
https://www.youtube.com/watch?v=3hW5eM5F...
https://radio-navicode.honda.com/
http://owners.honda.com/ownership/dealer...
这个答案有帮助吗?
得分 1
2条评论:
thanks alot for the info couldnt do it alone.
完成的
Donny, happy to be of assistance, good luck.
完成的
添加一条评论
最有帮助的答案
You can get a radio code here: https://radiocodevault.com/honda/
Hope it helps mate
这个答案有帮助吗?
得分 2
添加一条评论
If you can take out the radio and get the device serial number, you can look it up online at the site below. You will also need your VIN.
这个答案有帮助吗?
得分 0
添加一条评论
Hello, I think you should read the guide over at the below website, it will explain how you can get a radio code for your 1996 Honda Accord for free, give it a try. I've used it on both mine and my wifes Hondas and it worked perfectly both times. Beats paying the ridiculous fee at the main honda dealer!
http://www.freeradiounlocking.com/brands...
这个答案有帮助吗?
得分 0
添加一条评论
94 honda accord radio serial number 146035 the code number is 52652
这个答案有帮助吗?
得分 0
1条评论:
What about a 1995 Honda Civic coupe ex
完成的
添加一条评论
添加你的答案
Donny Armstrong 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 22
过去 30 天: 70
总计 14,117
