Where does spring go?
where does spring go in manual stapler
Eric Fields , I assume you are asking about the long thin feed/load spring which usually connects to a small tab on the staplers upper slide housing and to a tab on the slide. The links below should help you out in seeing spring mounting locations. On the guide link once you have opened it you can zoom in on where the spring is attached. Good luck.
这个答案有帮助吗?
过去 24 小时: 2
过去 7 天: 21
过去 30 天: 112
总计 44,541
2条评论
Where can I buy a spring for a nematic staple gun thanks Mary
由 Mary Fallon 完成的
This doesn't work for swingline 444
由 Izaakraaaaay 完成的
