跳转到主内容
加入维修社区 - 创建账户
一款专为 Apple 产品设计的微型投影仪。
no projection or light
Continuation has the purchase of a cinemin swivel, I have a problem:
When I switch on the pico connected to an ipod, an image is projected with the cinemin logo; but two seconds after, nothing more no projection or light which goes out of the device.
By looking the lens I has fault sees a small light at the bottom of the device
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Any fix for this problem with the swivel?
完成的
nyl777, it would work so much better for you if you ask your own question and give as much detail as possible if you are expecting any help with your device. Your two questions on ifixit actually show up as answer to older questions. Click on the link on the right hand side of this page, where it says" Ask a question" Give it a try, it is not difficult and you may get some help for your problem. Good Luck.
完成的
添加一条评论
4个答案
已选择的解决方案
Sounds Like a the bulb has burnt out. Hopefully its not to expensive.
这个答案有帮助吗?
得分 0
2条评论:
How to be safe that It is the bulb, because the device does not have was used
完成的
He reacts in the same way when no device is above connected
完成的
添加一条评论
Are you using it with an iPhone, iPod, or iPad? Because if you are, you need to use the little adapter. It should plug into the charger port of the iProduct, not the headphone port, and then the 3.5mm plugs right into that. I had this same problem, until I noticed the adapter lol
这个答案有帮助吗?
得分 0
添加一条评论
It may be the cord or the adapter. Sometimes, I have to plug my DVD player white into the yellow, and the yellow into the white in order to get the picture. It's like a crossed wire or something.
这个答案有帮助吗?
得分 0
添加一条评论
Does anybody know where I can find the blue cord that connects the cinemon swivel 8410 projector component with the battery component?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
specie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 3,209
