跳转到主内容
加入维修社区 - 创建账户
2014 年发布的 Toshiba Satellite Radius 系列笔记本/平板二合一电脑的维修指南与支持。
Why does my computer only work when connected?
My laptop does not work unless it is connected to a power source. I'm guessing it's the battery.
How can I check or know if it is. And how do I get a replacement?
I live in Mexico...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
I got a replacement Battery. But the same problem continues. Battery charging indicator repeatedly blinks from red to green. Battery indicates 100% charge but system does not work on battery power. Please provide solution.
完成的
We in our company bought 3 Toshiba Satellite P55W laptops, and all 3 had the same battery problem. After a year battery was dead!!!! Even replacement batteries are not performing well. Toshiba should say something about this obvious problem!!!
完成的
Hi @ Amara Wolfchild,
Have you contacted Toshiba about this then?
If they aren't told they mightn't know about it.
At least this way you should get an answer. Do it via email, that way you'll get a written response.
完成的
添加一条评论
1个答案
已选择的解决方案
Sebastian Guadarrama-Sistos , Below is a link to show how to open laptop to access battery for changing. 2nd link shows how you can google search to find a replacement battery using your computers make and model #, link 3&4 are guides telling you symptoms of a bad battery. Good luck.
https://www.youtube.com/watch?v=XrZYYE1n...
https://www.google.ca/search?q=toshiba+s...
http://www.howtogeek.com/172362/how-to-k...
http://www.dummies.com/computers/pcs/how...
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
Sebastian Guadarrama-Sistos 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 640
