Why is it starting to slow down?
mini mac late 2012
I Recommend Upgrading To 8GB Ram And A Solid State Drive That Would Make You Mac Mini Run Smoother Especially If You Are On Mac OS X 10.12.0 Or Above
这个答案有帮助吗?
You hard drive is to full. Anytime you get a drive more than 80% filled it will start to slow down.
Standard RAM: 4 GB Maximum RAM: 16 GB
Details: By default, 4 GB is installed as two 2 GB modules.
This model supports 16 GB of RAM using two 8 GB modules.
I would also recommend a Seagate SSHD 1 TB. Use the existing drive for storage.
Or
adding a smaller SSD drive and turning it into a Fusion Drive.
But you may to clean up the drive and eliminate duplicate items or whatever is taking up your HD space.
Here's how to add the second drive.
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 1,290
5条评论
Whats The Specs On It ?
由 Justin R 完成的
2.5 GHz Intel Core i5
4 GB 1600 MHz DDR3
Intel HD Graphics 4000 1536 MB
由 Ben Osterlund 完成的
Do You Have The Storage And How Much Is Used
由 Justin R 完成的
5 gigs, 418 still available
由 Ben Osterlund 完成的
Standard Hard Drive: 500 GB (5400 RPM) Int. HD Interface: Serial ATA (6 Gb/s) x2
由 mayer 完成的
