replace map sensor do it yourself
where is map sensor? and how to get to the sensor
Dicksen Mah , The MAP sensor on the Honda 1.7 engine is stuck in the intake manifold right beside the throttle body(driver side) held by 1 bolt. Remove plastic filter air ducting from above throttle body. Remove the map sensor by unplugging wire connector, remove the single bolt, then grab the sensor and with a slight twisting motion pull sensor out. Be sure the old rubber O-ring is still attached to the old MAP sensor. Install the new sensor in reverse order. See the 1st link below which will help identify the MAP sensor you want to replace and the 2nd link actually points out the installed MAP sensor at the 3:23 minute mark and shows how o remove the plastic air intake filter/housing. Good luck.
这个答案有帮助吗?
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 63
总计 14,050
