跳转到主内容
加入维修社区 - 创建账户
Furby 是一款颇受欢迎的电子机器人玩具,外形像仓鼠或猫头鹰。它在 1998 年假日季推出后,一度成为“必备”玩具,并持续热销至 2000 年。Furby 在 1998 年售出 180 万台,1999 年售出 1400 万台,在其最初生产的三年内,累计销量超过 4000 万台。
Furby thinks his shaking.
Furby thinks it shake in the vertical position and therefore always turns into the evil.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Same problem with the 2012 furby model... It also wakes up by the minimal vibration he senses... I've searched online but I didn't found any comments about this problem...
完成的
I have the same problem since my 2012 furby decided to jump of my drawer when I wasn't looking
完成的
添加一条评论
2个答案
最有帮助的答案
How to get your Furby to change personality?
Default Personality. All Furbies start off like this. You can get this personality back by turning your Furby upside down, holding down the tongue, and holding the tail pulled for 2 seconds.
这个答案有帮助吗?
得分 1
1条评论:
This isn't related to the shaking problem at all. The furby tilt sensor is probably at fault here. It's broken/too sensitive and even when furby moves by itself(while dancing etc) he thinks he's being shaken. But it doesn't have to work like that. For example as soon as I reset it it goes into the grumpy personality because he thinks he's being shaken. It also wakes up by itself after he fall asleep because the movement he does while he's closing his eyes it makes him think he's being shaken.
完成的
添加一条评论
If your furby thinks it shaking while in the vertical position and switches its personality to evil/Feisty/ Viking mode. The furby tilt sensor is broken or too sensitive. For instance, if the furby dances, he may stop, since he thinks he's being shaken. I advise to take apart the furby to clean/replace his tilt sensor
This site might help even though it's for older Furby's:https://furbytech.tumblr.com/post/167541...
这个答案有帮助吗?
得分 0
2条评论:
Have you had any results fixing the issue in the 2012 furby? I'm having the same issue, and I found like 1-2 posts on reddit where people talked about not being able to fix it in their 2012 furbies / not being able to locate where the tilt sensor even is
完成的
@qhwohwfj I think I know which one is the sensor. It's the black "box" thing on the side of the Furby. On the pcb where there are others components. I actually thought it could be that when I disassembled the Furby a long time ago and I think there is a way to open it.
This site might help: https://furbytech.tumblr.com/post/174003...
or: https://learn.adafruit.com/furby-2012-te...
also: https://www.bot-thoughts.com/2013/03/fur...
This video is a full teardown so it may help as well: https://www.youtube.com/watch?v=DTp_gPqS...
There is sadly very limited information on Furby Tilt sensors out there.
完成的
添加一条评论
添加你的答案
iambelkin13 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 35
总计 1,757
