跳转到主内容
Model 5234us. 1.66GHz Intel Centrino Duo
How to put the Ribbon back rightin the compuyer
I took out the ribbonon my computer hp pavilion dv5000 to put in new one and for got how the ribbon go back in can your help me out here please thank your I took the ribbon out of the computer to put in new ones but for got how to put them back in right can your show me how to put them back inThank your
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
As you do not say which flex ribbon cables you are asking about, here is a link to the service manual for your laptop.
If you scroll to section 3-4 it gives an exploded view of all the parts in the laptop. Once you have identified the particular cable that you are interested in, its' identity should allow you to find where it is connected to in the service manual and from there it should tell you the necessary pre-requisites and then the procedure to remove /replace the cable and the associated component that it is connected to.
http://www.hp.com/ctg/Manual/c00700959.p...
Hopefully this is of some help.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
david michie sr 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 113
