跳转到主内容
加入维修社区 - 创建账户
Atari 2600 或 Atari Video Computer System (VCS) 是一款于 1977 年 9 月发布的游戏主机。2600 运行 MOS Technology 6507 CPU,并使用 ROM 卡带存储游戏。
The screen seems dark
I just found my old 2600 in my garage, I cleaned it up and even fixed one of the controllers that was broken inside, so when I plug it in and turn it on the screen seems a lot darker than I remember it looking, what could cause this? everything else works fine.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论:
@kazman72 how did you connect it to your TV and what TV are you using?
完成的
I used the rca cable to the cable coax adapter method, I'm using a newer samsung hd tv.
完成的
Did you check your RF switch on the back of the console? And the tip of the cord that goes into the console? Sometimes it gets dirty over time and doesn't get a good connection. I would suggest unplugging everything the get a qtip with rubbing alcohol and cleaning the connector on the console and the end of the cord. That works for me.
完成的
添加一条评论
1个答案
Try checking the screen settings on your television. On my LG I can set different lighting settings for different inputs, and some cause the screen to appear darker than others. Each input on your television will have different pictureh modes so setting it on one input will not automatically transfer it over to another.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jonathan Kazarian 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 18
总计 871
