跳转到主内容
加入维修社区 - 创建账户
与AirPort Extreme基站一起发布,这款配备硬盘的Time Capsule NAS上提供802.11ac速度。
Time Capsule not powering on
I've been using this device for about 1 year until one day I found the light blinking amber. The Airport app was reporting the device was overheated. I pulled the plug and waited for it to cool down and when I plugged it back in there was no light at all. All I could hear was the noise of HDD spin up and nothing seemed to work.
It's out of warranty so can't take it to apple.
I cracked it open and found out that the PSU seemed to be functional. I checked the output voltage and it was a solid 12 Volts. But the fan doesn't run at all. I even tried to apply voltage to the fan to see if it runs but it didn't.
I checked the fan socket on the mainboard and 12 Volts appeared on the multi-meter.
Can I be sure that the fan is faulty? Because I don't want waste money on a PSU to find out it was not necessary.
BTW can someone verify that a working TC acts like mine when no fan is connected.
Thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
10条评论
@shoeib hey bro, did you find a solution?
由完成的
@ironjer - I'm sure a new fan fixed the cooling issue
由完成的
@jesus no man. I eventually came to the conclusion that the logic board is fried.
由完成的
@shoeib maybe a bake... mine TC no fan spinning and no front light either but, the hard disk power on. I don't want waste money in new PS. :(
由完成的
@danj I have no front light and no fan spinning, just the HDD works. Maybe the Logic Board is failing...
由完成的
显示更多的5条评论
添加一条评论
2个答案
已选择的解决方案
More likely the fan died here. For about $20 US you should be able to find one.
I don't have a A1470 TC right now but I've had to replace quite a few fan units across the entire line of TC's
这个答案有帮助吗?
得分 1
3条评论:
Do you by any chance remember how the TC acts with a faulty fan?
Thank you
由完成的
@danj would TG Pro read this?
由完成的
@mayer - TG Pro won't work here. It only works under OS-X or MacOS. The TC's use a custom file system and its own OS. AirPort Utility will report if the unit is overheating.
由完成的
添加一条评论
See if any of the following articles can help:
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
shoeib 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 14
总计 3,500
