跳转到主内容
The twelfth and final generation of the Cadillac Eldorado was introduced in 1992 as a two-door coupé.
29 个问题 查看全部
Anyone know what fusible link part number I need -solved alternator
Got two blocks away during snow storm this week end, it was 9 degrees, go to turn a corner, engine chugs twice and dies in the middle of the intersection. No battery power at all. Am I correct in assuming that the cat will continue running without a battery once it is running , could this be a battery cable? The car had cranked just fine just minutes prior to this happening. Fortunately a couple of guys pushed it to the curb for me. I don't know that much about auto mechanics. But I know how to research and use Google. Went back to fix it today and still totally dead, can't even lock the doors. I think it's the fusible link from what I can research but I wanted to get another opinion like from @lpfaff1 before getting my lilly white hands all grubby ;-(
I contacted Auto Zone and that was like talking to an Apple Genius. He was trying to sell me a fuse. I found this but do not know which one to get for a 1996 Cadillac ElDorado LTD. Anyone knowledgable about this?
http://www.elsiemfg.com/product-category...
UPDATE 1/12/16
Put in a new high end battery and it cranked right up and I got it home. NEW PROBLEM - I'm getting no charge to the battery. The alternator belt is a serpentine and appears good. I'd like to look for a cheap wiring problem before I even think about replacing the alternator, at my age, that's a visit to the dealer. @lpfaff1
UPDATE 3/3/16
The new battery and alternator helped. Then I found myself at the grocery store with a dead car. Turned out there was a corroded battery connection tab that was only allowing partial charging.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
19条评论
I have also seen where the battery cables have become so green inside that power would stop running through them.
完成的
Your caddy may not run with battery disconnected especially if something else is on drawing power or if alternator weak.
完成的
@mayer what happens when you boost your Caddy? Does it do anything with that?
完成的
@oldturkey03 Have not tried as it cranked just fine but died 4 minutes later and there is no sign of even a dead battery being connected. I've had batteries go bad before but you at least got some power to the interior lights and dash. It is totally dead, I can't even lock the doors with the key.
完成的
Give it a try and see what you get with a boost. There is no "fuseable link" in the Caddy's but there are 2 banks of Maxi fuses, check those. I seem to recall that Cadillacs use something like a Battery Guard Programmable battery protection to prevent accidentally draining of the battery. This will shut of all electrical power and it turns back on with activity on the information center, opening door etc. The point I am trying to make, that if you have zero, nada, null power with a boost or new battery, then that is where I would start. You need to get at least a light, dash or otherwise, with a new battery.
The MaxiFuses and relays are located next to the engine
compartment fuse block on the driver’s side of the
engine. I'd be looking at BATT1 BATT2 BATT3 just to make sure.
完成的
显示更多的14条评论
添加一条评论
2个答案
已选择的解决方案
@mayer , Not familiar with Cadillac fusible link, but could be the issue. Check the battery connections as a first step, remove/clean/tighten/ check for 12.2 v minimum check ground to engine, follow positive wire to where ever it connects and check/clean/tight and try. Check all your fuses, you may have 3 or more fuse box locations(not positive) a couple under hood and one in the trunk. Try giving it a boost.
Found this info. at just answers, one fusible link that is inline with the positive wire that runs from the alternator to the fuse/relay center on the left side of the engine compartment. I will keep thinking on this and get back if I have any other suggestions, hopefully others will step up in helping solve. Good luck.
这个答案有帮助吗?
得分 2
添加一条评论
My fuse box has power but not all the fuses have power f11has power but f10 don't what do u think
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mayer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 25
总计 6,514
