跳转到主内容
加入维修社区 - 创建账户
关于“Logitech G602”(无线游戏鼠标)的背景信息。
Screwed up during desoldering?
I'm totally new to soldering and I thought I could give it a try replacing the micro clicker for my G602 Logitech mouse.
I had a very hard time desoldering the old micro clicker out and I kinda messed up.
(I don't really know what a copper pad is), but I think I damaged one while desoldering. Located on the top right of the photo. I'm not sure if I damaged the others as well.
https://pictub.club/image/sytWkn
More pics.
1 removed both micro-clickers. Compared to the one below, the one on top looks blackish and burnt. I'm afraid i burnt the top PCB by putting the tip of the solder iron too long?
https://pictub.club/image/sy5RHZ
The other side of the PCB.
https://pictub.club/image/sytxXi
I'm just wondering if there's any way to salvage this PCB ? I'm not putting my hopes high in fixing this mess but I thought perhaps someone could help/guide me. Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
What method of desoldering are you using copper wick or suction? So far it looks fine your on the backside the connections are on the front and your only removing the anchors you have three to go . Clean the area with electronic flux (resin)which is different than the flux used by plumbers(to corrosive for circuitry) then solder in your new switch. Make sure you use electric solder specific to circuit work not plumber solder. Common mistake amoungst first timers. Keep going you only succeed by trying. Hope this helps
这个答案有帮助吗?
得分 6
10条评论:
I'm using a copper suction; but seemed alittle difficult clearing up the holes. Might try again when I'm free. Would a copper wick be better ?
So far, I'm just a little worried about this.
https://pictub.club/image/syfdfF
Is it damaged ? or it'll work fine after i solder back a new switch ?
完成的
joscmh90 like @jimfixer mentioned, so far it does not look bad. It looks to me like you are having issues with the desoldering by either not using, or not using enough, flux. Also, those little vacuum gadgets are not the greatest tool. Get used to using heat, place lots of flux on the solder pad and I use plenty of flux on the desoldering braid as well.
Right now from what I can see, it should work once you properly solder the switch in place.
完成的
the dark area is blacken from lack of flux the flux keeps your work clean . I prefer to use braid . it works fast and does a good job of cleanup. the area your concerned with is not damaged its just need to be cleaned
完成的
@jimfixer @oldturkey03 Another thing I failed to mentioned is that from the area that I'm concerned, while desoldering there's also this square dark green border surrounding the copper pad which got detached. Would the blacken area be due to excess heat? I could have placed the soldering tip there a little too long. I think I even tried placing the tip into the hole to get rid of the solder inside (which I failed).
I have this with me, is this flux ?
http://www.ebay.com/itm/Burnley-Solderin...
I'm still trying to figure out how to use flux. Do i just apply the paste all over the area I want to desolder and heat it using the soldering iron ?
完成的
joscmh90"placing the tip into the hole to get rid of the solder" that is whty you need desoldering wick and flux. It will prevent those things from happening. Yes, that is flux. Not sure about your "square dark green border" we would have to see this to judge it.
完成的
显示更多的5条评论
添加一条评论
it seems your 1st pin on your right switch pcb in trouble....try to clean it first and repost the picture, maybe it still any path rest so you can solder it again to the rest....or you can try to 'break' the pcb (really careful and DWYOR), and you can find the path then you can try to jumper it via jumper wire....goodluck
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
joscmh90 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 33
总计 1,683
