跳转到主内容
The Bose Wave Radio AWR1-1W, also known as the Bose Wave Radio I, was released in 1993. A countertop AM/FM radio system with a high performance stereo tuner and two independent alarms.
33 个问题 查看全部
Can you fix a Bose Wave radio/CD player?
Can you fix a Bose Wave radio/CD player???
Update (12/31/2016)
When I put in a CD, it begins spinning rapidly. There's no sound coming out and I lift the lid to manually stop the spinning. Then I have to pressStop, open the lid again and try to start the music. Sometimes it works, sometimes I have to keep doing that.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
13条评论
I can put a CD in, nothing happens. The radio is great, the alarm is fantastic, but I cannot play my new Glen Campbell CD, ADIOS. No one in San Angelo repairs Bose. Sure appreciate any help given.
完成的
I have the AWMS III SERIAL 023580C22290633
The CD player doesn’t play
It turns, but no music.
How do you clean the player?
完成的
My radio and CD no longer function?
完成的
cherylfurze what exact model is it and how does it not work? does it turn on? what have you checked?
完成的
The cd on the wave radio and 2 of the 3 cd slots in the attached changer will not exit. They are stuck and will not play. Only the radio is working. Can this be repaired?
完成的
显示更多的8条评论
添加一条评论
3个答案
已选择的解决方案
hedon2000 no but you possibly can fix it. Let us know what it is doing, or what it is not doing so we can try and provide you with some help to get it fixed
这个答案有帮助吗?
得分 3
1条评论:
It gets hot after the CD is playing for about four or five tunes
完成的
添加一条评论
I just had mine fixed by a Company who specializes in this since Bose itself no longer supports this model.
They did a great job. Norbern @1 (800) 379-2073, +1 (719) 550-5810 or toni@norbern.com
这个答案有帮助吗?
得分 0
添加一条评论
I have a Bose Wave Radio/CD player, and the cd player just stopped accepting cd's....error message: cd not playable. I researched the Bose site and tried lame fixes, and then "signed up" for repair. The 'repair' was for Bose to sell you an updated, new system with a slight discount ( which I found I could get online, anyway). I tried cd cleaners, no fix. I finally got the idea, since some players are mounted vertically, etc., to insert a cd, lift up the unit and slant it 45 degrees....voila! It took the cd, and now works perfectly fine again !
So much for Bose being a great company. As much as I love the technology and performance, this is no way to treat customers !
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
hedon2000 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 37
过去 30 天: 142
总计 7,476
