Replacing the drivers window because the attachment Clips are broken o
How to remove the passenger side window and then replace it
@jesscuz , Jessica, Broken plastic window mounts. Video below will show at approx. 4.30 mark the bolts that need removed to enable window removal and install. This is the driver side window but pretty much generic to the passenger side. Good luck.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 157
1条评论
@jesscuz not sure which attachment clips you are referring to.
Rep: 1
由 oldturkey03 完成的
