跳转到主内容
加入维修社区 - 创建账户
2014年10月5日发布的高清运动摄像机。
water damage liquid damage
my go pro hero 4 has fell into the water without a case and it wont turn on I am very worried plz help if you can thank
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Hi,
As you know water and electronics and electricity are not a good mix.
The water causes corrosion and provides circuit paths for the electricity which were not in the camera's operating design and could damage the components.
First do not turn on your camera and then you need to remove the battery as soon as possible from the camera to minimize further damage.''
Then you need to dis-assemble the rest of the camera and clean all the affected parts using Isopropyl Alcohol 90%+ to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% and is not as effective. If you do check the label to verify the amount
Here is a link that in general, describes the process.
Electronics Water Damage
You may have to replace the battery as it is very hard to recover a battery from water damage.
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the camera might possibly work correctly again.
Here is a link to the ifixit guide on how to replace the lens in your camera. It is useful because it shows how to open your camera so that you can access the components inside to clean them properly.
GoPro Hero 4 Black 摄像头镜头更换
If this process seems too daunting, take your camera to a reputable, professional camera / electronics repair service and ask for a quote for a repair.
If you decide to do this, do it sooner than later.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
billocara619 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 15
总计 4,227
