跳转到主内容
Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544 个问题 查看全部
Does the guide end prematurely?
This guide was a bit difficult to follow because the photos didn't represent 'exactly' what I was seeing. I was able to find the corresponding connections.
The trouble I'm having is the guide seems to end a few steps too soon. I still have a display inside the upper shell, the piece with the Apple logo. I'm very concerned for the well-being of the 'old' pieces in question. I have to save the upper case piece while extracting the display.
Any ideas please?
Update (01/02/2017)
I had to take a break from this and am back now, hopefully ready to tackle the rest of this display replacement.
I've looked at the 15" display replacement linked above and have concluded that the differences are sufficient that following it for my purposes isn't likely. My next step is to remove the display itself from the upper case it is mounted in. The problem is I'm unable to find any resource that talks about how this comes apart. I'm attaching a photo for whatever purpose, maybe so the differences can be visualized.
Does anyone have a resource that shows how this comes apart? Should I post this as a new topic in the forum? Thinking maybe I should.(?) Thanks in advance for any thoughts on this.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Yes, give us a link to what you are talking about.
完成的
添加一条评论
1个答案
已选择的解决方案
Where you trying to replace the display? Following this IFIXIT guide: MacBook Pro 17" Unibody Display Replacement. If you jump down to the very last step (Step16). Once you get lid disconnected from the main body it just swivels out.
这个答案有帮助吗?
得分 2
8条评论:
@danj sounds to me like he is tearing down the display repair it. not replace it.
完成的
mmm... So what he wants is something like this guide: MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement here in this set of guides.
完成的
Hello Dan,
Step 16 is where I and the guide ended. Disconnecting the 'lid' half from the 'keyboard' half is fairly simple. Once the 'lid' (or upper case) is separate from the lower case then removing the display from it for replacement is/are the steps missing. I have the replacement display in front of me and it didn't come with the upper clam shell piece (that has the Apple logo on it).
Am I any more clear?
完成的
Buz - I think both Mayer & myself see whats up here.
The guide is complete as the assumption is you are replacing the assembly Vs the discreet LCD screen. Hopefully the second guide I made a link to can help you. While not exactly the same model Apple was consistent enough the guide should work.
I agree, we do need a few more guides that get into things a bit deeper across a few systems.
This is where people can help out! Please consider creating a guide here's the start point: Create a New Guide
完成的
Dan, mayer, Seems perhaps there's a terminology issue. My concept of the 'display' is the screen itself and not the enclosure that contains it- my luck there's a terminology bank somewhere that perverts my concept - (laughing). I have looked at the link for the MBP 15" screen replacement. It looks EXTREMELY difficult. So much so I may reverse direction and let my friend find someone else do it. Using heat guns on equipment like this is completely subjective - makes my hands shake to think about it.
OT - how do you mark up in the comment section? Such as mayer's repair link?
完成的
显示更多的3条评论
添加一条评论
添加你的答案
buz 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 75
