跳转到主内容
The JBL Charge 3 can be recognized by its distinct woven speaker cover and rubber accents. It was released in 2016 and features a fully waterproof design, 20 hours of playback time, and bluetooth connectivity.
Only turning on while plugged in
Hi,
I recently bought a JBL charge 3. Since today, it won't turn on when it's not plugged in. I didn't blow it and the battery is full (all 5 light are on). How can I fix this or do I have to go back to the store?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 11
26条评论
ive got the same problem, i tryed everthing.
It turns of thats all.
完成的
I have the same problem. Tried everything. I press the power button but blue light turns on for one second and then turns off. The white blinking light is constantly on. It won’t charge. Completely brand new arrived yesterday and it worked for 10 min and battery dieded.when I turn it on and press Bluetooth and volume up it completely turns off and I unplugged it and it’s just black. When I plug it back in white light comes back
完成的
just did the update… it killed myJBL Charge 3 no power after update.
1) my device is fully charged.
2) i tried every combination possible… no good!
There is no lights out power and the charge does nothing to help… I've tried plugged in and not plugged in… no good.
it's totally dead :-(
完成的
Same problem here :( Now I'm trying to find any solution, hopefully there is a way to fix it somehow...
完成的
Same problem here I’ve tried everything, is it maybe a hardware problem where something has to be fixed/replaces?
完成的
显示更多的21条评论
添加一条评论
4个答案
已选择的解决方案
If your JBL Charge 3 speaker is not playing sounds, lighting up, or turning on at all, see the JBL Charge 3 Won’t Turn On problem page for possible problems and solutions.
You need to charge your JBL and when the power button turns on you have to press the volume+ and the connect button at the same time until it shuts off.
Then you pull the cable out and start it.
这个答案有帮助吗?
得分 34
38条评论:
Brilliant it worked, tried lots of other ways recommended and this was the only one that worked. Thank you
完成的
I tried it but it's still not turning in blue light mode only white
完成的
Thank you, It worked!
完成的
Hi all,
I did the method posted by elias and paulogutobh got the blinking red lights and the power button turns blue The unplugged and hit the power button and still no power. I am guessing the battery needs to be replaced? I got this unit second hand.
完成的
Easy fix for this is
Hold volume+ and that one for left side like 15 secs its should show you same red light but after that its successfull working. Its like somekind of child mode
完成的
显示更多的33条评论
添加一条评论
I have seems multiple posts of different button combos being held for 10s to reset demo mode. My fix was the BT button and the “play” (right triangle) button. Try different buttons paired together for 10s and the power light goes out as it powers down and then you can hit power and it will be operational. So many people have been saying the batteries are dead but I have 5 of these and never once has the battery been the issue. Good luck!
这个答案有帮助吗?
得分 5
11条评论:
Pressing the volume+ and the connect plus button together for a few second whilst it was plug in with the white light ON worked on my Jbl boombox.Thanks
完成的
This fixed this problem for me. All of the sudden the JBL would not function and power down once unplugged. After this it worked again.
完成的
My boombox i bought it brand new it won't power at all. no light indicator on even plugged in nothing happen any helps pls
完成的
It worked for me, thanks!
完成的
That solution worked for my JBL FLIP 3 !
1) Plug it in
2) Hold Bluetooth pairing + PLAY button for 5/10sec
3) you'll hear The Start up Sound
4) Unplug
完成的
显示更多的6条评论
添加一条评论
I have my jbl clip 3 it's almost dead i believe.
But there are few conditions it's turn on.
Primarily it's sound goes off very little sound can be heard. No base.
I tried reset method then it start giving these issues.
  1. Not turning on with power button.
  2. When plug with usb for charge it shows 1 time red light blinks and goes off and show solid white light.
  3. I try to combination of volume+ and Bluetooth paring button it goes off but not turn on.
  4. Please help me to identify the problem.
这个答案有帮助吗?
得分 0
1条评论:
添加一条评论
What I did.....
  1. Take apart the unit....it's easy. Follow how on ifixit here
  2. Get the battery out.....get the model number from the battery
  3. Go to eBay and search and you'll find a lot of them
This will fix your problem. I have done this several times over the years...in fact I replaced the speakers when they were blown! Got them from eBay as well. Good luck!
这个答案有帮助吗?
得分 0
3条评论:
I have installed a new battery in the JBL Charge 3 as you suggested. The battery now seems to charge and the LEDs indicate the charge level correctly. However, it only responds to the power button when USB is connected. If you then also establish the Bluetooth connection, you can play music and even remove the USB cable, the device then continues to work until you turn it off. To turn it on, however, it needs the USB charging cable again with the above procedure. Switching on without the USB charging cable remains unsuccessful. I have already tried all possible resets suggested above without success. Any ideas?
完成的
Try this. Sorry for such a late reply
https://youtu.be/EGhokPrmuM4
完成的
Maybe you already did this. If so and the problem persists, get a new motherboard off eBay and that's about it 🤷
完成的
添加一条评论
添加你的答案
Fadeux 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 48
过去 30 天: 267
总计 121,444
