跳转到主内容
加入维修社区 - 创建账户
2011 年发布 - Core i3-2330M 处理器
non stop shutdown turned on loop
my laptop goes on a turned on-shut down loop.first it went on on its own without me pressing the power button,then after 2-3 second it turned off on its own without me reaching the windows screen.can someone help me?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Sounds like you are boot cycling... this means there is a hardware problem, and is commonly a storage problem... I would say take out the HDD and see if the bios will load but I have have one of these all though be it a intel core i5 from old but this computer has the worst HDD placement ever... as in need to remove the motherboard from computer bad... and that may not even be the problem.... but try this first, reseat the ram (take out and reinstall) and see if it boots
完成的
添加一条评论
1个答案
Looks like you have a gpu failure.
Sometimes helps if you take it appart and clean the cooling sistem , but in most cases the only solution is the gpu reflow / reball.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
fahri a 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 326
