跳转到主内容
加入维修社区 - 创建账户
Acer Aspire One 722 型号 #P1VE6 是一款于 2008 年 7 月发布的上网本。
Power LED blinks blue 5 time .
What's it mean when the #1 LED flashes blue 5 times;when I try power on my Aspire one 722-BZ454?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 6
4条评论
Is is normal that it still blinks in every process that I turn it on? During process…
由完成的 分享
Still not coming on and blue light still flashes 5 times.
由完成的 分享
I try this but Not solve my problem
由完成的 分享
I tried but didn't work plas. Help with any other method as I am having an acer aspire 3
由完成的 分享
添加一条评论
8个答案
已选择的解决方案
Hi,
It means that the battery in the laptop may be flat.
Try the following to see if you can get your laptop to start:
1. Disconnect the power adapter from the laptop.
2. Remove the battery pack from the laptop. This link shows you how to remove the battery
3. Press and hold the Power button on the laptop for 10 seconds.
4. Reconnect and switch on the power adapter to the laptop. Leave the battery out at this stage.
5. Try to start the laptop. If it starts allow it to boot all the way to the Windows desktop. Allow the HDD to settle (i.e. wait a few minutes)
6. Shutdown the laptop in the normal manner.
7. When the laptop has completely shutdown, switch off the AC adapter and remove it from the laptop.
8. Re insert the battery pack into the laptop.
9. Reconnect and switch on the AC adapter.
10. Try to start your laptop. If it starts allow it to boot all the way to the Windows desktop.
11. Check the charging status of the battery. If it is charging allow it to fully charge before switching off the AC adapter and removing it from the laptop.
If the laptop doesn't start at Step 5. you either have a faulty AC adapter (and that is maybe why the battery went flat) or you need to check that the wall outlet is working correctly.
这个答案有帮助吗?
得分 19
12条评论:
That's right !Perfectly! Тhank you very much for prompted !
由完成的 分享
You saved me. Thank you! Your awesome sauce!!!!
由完成的 分享
Excellent detailed easy to follow and effective action list.
As I said ... Excellent !
由完成的 分享
I don't know what's happening, but the orange light doesn't blink and my laptop won't turn on
由完成的 分享
Mine blinks 5 times, I take the battery out and it doesn't start. I do have power in the outlet, also tried another power adapter, they're both working.
由完成的 分享
显示更多的7条评论
添加一条评论
I had the same problem and I simply pluged my computer to the power adaptater.
I turned my computer on and I see a windows update.
It worked for me ...
-- I'm French and I speek not English as well as an English--
这个答案有帮助吗?
得分 3
1条评论:
Merci beaucoup
由完成的 分享
添加一条评论
Press and hold the battery reset pin hole on the bottom of the laptop (google it to find out where, but just look you’ll find it). I used a pen ink and pushed and held it in for 5 seconds. You have to do it with the battery in. It didn’t work while the battery was out. With the back battery in, I pressed the power button and it turned right on.
这个答案有帮助吗?
得分 2
2条评论:
Thank you so much. This worked. I was stressing because my laptop didn't turn on and I need it for work. Thank you so much. You are a star. The other prompts didn't really help
由完成的 分享
Thank you so much this worked for me too.
由完成的 分享
添加一条评论
Black tape over the led, and live with 90% or 94% battery.
这个答案有帮助吗?
得分 1
添加一条评论
I'm having the same issue with an acer aspire that has 7 months of use. I’m unable to remove the battery because it's different then the quick link suggested. I pressed the battery reset pin hole for 5, 10, 20 and 30 seconds with and with out the charger connected and there's still a black display. This sucks
这个答案有帮助吗?
得分 1
1条评论:
Ram issue perhaps, not the right size (12800S / 10600S / 8400S). Or there’s 2 different ram specs (1Rx8 / 2Rx8)
Both those numbers on the ram have to be the same, if there’s a ram issue the display generally won’t work but ths lights on the board will still.
由完成的 分享
添加一条评论
I have the same problem. But when I took the battery out and try to start it. It power up but didn't boot up, just shut down again.
这个答案有帮助吗?
得分 1
添加一条评论
I have just replaced my E1-571 laptop base I put it all back together and all I get is 5 blinking blue lights no boot up etc yet it was working yesterday any help please
这个答案有帮助吗?
得分 0
2条评论:
@robking123 a quick search on G gave the following link to the acer community forum: https://community.acer.com/en/discussion...
Apparently this user had the same issue and could fix it by resetting bios settings (just remove the CMOS battery and wait for some mins), won't hurt to try it out, keep in mind that previous configurations will be reset to default
由完成的 分享
I found a lose cable on the DC port so soldered it back on that gave me windows now I can't get my WiFi working on the laptop any ideas ?
由完成的 分享
添加一条评论
My acer was blinking a blue light when l tried pressing the pin hole for 5 sec now it is not turning on or blinking the blue light
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
dvshand 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 40
过去 30 天: 224
总计 177,423
