跳转到主内容
加入维修社区 - 创建账户
Big Wheel 是一种通常由塑料制成的三轮车,前轮尺寸超大,骑行位置非常贴近地面。
Steering column is stiff
I recently put together a kids big wheel and the steering column is very stiff and will hardly turn. Obviously this isn't something that is adjustable given the set up, but I need simple solution so my three year can steer it. Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Try adjusting the height of the handlebars by loosing the screw in step #5 of this PDF and lifting slightly till it turns freely then tighten it back down:
originalbigwheelparts.com/images/bw_assy_instructions_pictoral.pdf
这个答案有帮助吗?
得分 2
4条评论:
Kristina Johnson, This may also help, take the column back apart and apply a little/ thin coating of Vaseline on column and reassemble. Good luck.
完成的
Neither of the above helped a bit. Cannot be steered by a child.
完成的
Item is a piece of junk.
完成的
Agree, the Big Wheel has been unused for over a year. Every few months my kids and their friends get on it and just as quickly get off. I would greatly appreciate someone sharing a fix if there is one out there
完成的
添加一条评论
To any parents who bought this for their kids for Christmas and are running into this problem - the solution is candle wax!
Simply apply a thin layer of wax to any surface that rubs in the steering assembly (underside of the handlebars, front fork spindle, inside the hole the spindle goes through, etc.).
I was a little skeptical given the apparently unsuccessful petroleum jelly suggestion, but gave it a shot anyway, as I've used candle wax to lubricate wood in the past.
Not sure how long the effects will last, but it works great so far!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kristina Johnson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 15
总计 2,242
