跳转到主内容
加入维修社区 - 创建账户
Moto G4 Plus 是 Motorola Moto G4 的升级版。Moto G4 Plus 提供指纹传感器、更大的内存容量以及改进的后置摄像头。型号为 XT1642 和 XT1644。
moto g4 plus Micro USB Replacement
Can you put up a video on how to replace the micro usb port on the moto g4 plus?
Mine had the plastic literally melt after connecting in to an apparently faulty car charger.
Much Thanks and keep up the great videos!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
4条评论
Your phone didn't warn you what was happening?
由完成的
Hi, did you solved this problem? I need to replace my charging port too.
由完成的
Nope, ended up sending it in on warranty and getting a new phone.
由完成的
Hi
I purchased a rebuilt Moto G 1st generation smartphone but the charger port was broken after I paid for it , and before I received it.
Can you provide an instruction manual or video? I have seen one but the soldering alone I know is more than I can do myself. Can you help?
由完成的
添加一条评论
1个答案
最有帮助的答案
william_oliveira87, John Linden, If port is found to be bad/loose/damaged , this is really not a repair for the inexperienced because the charge port for your device is soldered to the mother board and the heat generated could cause further damage if not very careful. I will post a link to a tear down guide to get you inside the tablet to check the charge port and will also post a link showing what is involved in repairing a USB charge port attached to the board. The last link is to new charge port, which you can also do a search for better pricing perhaps if needed. If not wanting to do the repair yourself have a good computer/cell phone repair shop have a look and estimate repair. Good luck.
https://www.youtube.com/watch?v=8jqw-KwC...
https://www.youtube.com/watch?v=Bl_6g4GV...
http://www.ebay.com/itm/2X-Dock-Connecto...
这个答案有帮助吗?
得分 7
添加一条评论
添加你的答案
John Linden 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 20
总计 10,942
