跳转到主内容
An easy to use home Espresso machine created by Saeco and rebranded for Starbucks. This machine is excellent for every day espresso drinkers and has an excellent build and product life.
140 个问题 查看全部
Accessing Service Manual referred to in tear down section
In the intro to the teardown section there is a reference to a service manual which appears active. When I click on it I am simply taken back to the first page. How can I access this service manual??
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
@staz staz @lpfaff1 most likely because you are looking at Student teardowns. Could be that they are unfinished, or will not get finished. Isn't Starbucks Barista not just a rebranded Philips Saeco machine? try to do a search on those.
完成的
添加一条评论
3个答案
已选择的解决方案
@staz , peter, I get the same results when I key on the service manual , either it is still in the works or there is not a service manual, there is plenty of other info./guides on the Barista, from tear downs, testing items to trouble shooting, hopefully they can help. I did try a google search also and did not find a service manual. If you have a particular problem, post your problem as a new question with all the info. and one of the ifixit volunteers may be able to help. Good luck.
Added a couple links below that may help.
https://www.espressocare.com/products/st...
https://espressodolce.ca/parts-diagrams/...
这个答案有帮助吗?
得分 2
添加一条评论
@staz @lpfaff1 most likely because you are looking at Student teardowns. Could be that they are unfinished, or will not get finished. So, there may not be a service manual. Isn't Starbucks Barista not just a rebranded Philips Saeco machine? Try to do a search on those.This, combined with some of the students work, may be a start for you.
这个答案有帮助吗?
得分 1
添加一条评论
There is no official repair manual for this machine; if ifixit is working on one it hasn't been posted yet.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
peter stazicker 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 139
