does not poke coffe pod
can I get my Kurig coffee maker repaired........it doesn't poke the pod for the water to go through the pod......... feels like it might be bent ???
@esmills__16 if it is truly bend you can replace the needle assembly (depending on your model). Every now and then you can find the parts at places like this. On this guide in step 9 you see two small Philips head screws on the left hand side (above and below the water inlet). Those hold the needle assembly to the top part. Remove those to remove the assembly. Again, take lots of pictures and post those with your question by using this guide.
这个答案有帮助吗?
It looks like the bottom needle that punctures the bottom of the coffee pods has come out of the assemble. Can I put it back in or do I need to get a whole assemble replacement?
这个答案有帮助吗?
I took the bottom assembly out, but I didn't see a needle. It no longer makes a hole at the bottom. What can I do?
这个答案有帮助吗?
过去的24小时: 19
过去的7天: 114
过去的30天: 475
总计 21,032
@esmills__16 can you post some images of the puncture needle? Use this guide 在已经存在的问题里加入图片 for that. What exact model is your Keurig?
由 oldturkey03 完成的
no photos but he took it apart and back together again....and it is working.....thank you so much for your help........Ellen.
由 Ellen Sergas 完成的
I am new to this site, but i am trying to figure out why the exit puncture needle is not poking a hole through the bottom of my coffee pod that i put in?
由 tammymartin16 完成的
I am having the same problem!
由 Jolene 完成的
I'm having the same problem. So I improvised and punctured a whole at the bottom and it works.
由 Ericka Barrett 完成的
显示更多的2条评论
