跳转到主内容
加入维修社区 - 创建账户
第六代 iPod classic 。机型型号 A1238,80/120/160 GB 机械硬盘,黑色或银色金属前面板。
What should I do?
i had the same problem too and i know what causes this. my ipod had been drench twice. at first it was still working until it ceased to respond( same as aditya's issue) BUT! it soon start working, then a month later it ceased to respond again for 3 days, then a week, a month. then came the second disaster, it ceased to respond(same issue) forever, its been 6 month and its still not working. thinking that my ipod may have corroded inside and already doomed i decided opened it and found very little corrosion, but its from the frame work not on the logic board. please help. what should i do? should i get a new click wheel? what if it still not work with a new click wheel?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Dyords you do want to go ahead and disassemble your device. Use these guides for that. Then clean your board with some 99% isopropyl alcohol and a small brush. It is important that you clean all the connectors as well. Inspect them for corrosion with a magnifying source. Once you are satisfied that there is no more corrosion, reassemble the iPod. It is easily possible that the clickwheel has failed due corrosion from the water damage. Yes, go ahead and replace the clickwheel and the battery as well. This is important since the battery will eventually fail as well. The battery and clickwheel are inexpensive enough and a good starting point should further troubleshooting become necessary.
这个答案有帮助吗?
得分 4
2条评论:
like i said it has very little corrosion, and i doubt that this causes this since the corrosion only apear on the metal frame and not on the important parts like mother board and click wheel , but still i tried cleaning it, and still it doesn't work. i guess i have to replace battery and click wheel then? I appreciate your help!
完成的
Dyords I'd definitely start with those parts.
完成的
添加一条评论
relax. Get some rice. get a bowl. Make yourself the rice and eat it.
Then, take isopropyl alcohol. open up your device and using an antistatic brush, scrub down the whole motherboard with the alcohol. Then put it in an ultrasonic cleaner, or have a pro do this.
if it still doesn't work, take it to a board level repair specialist.
Then, while this is probably overkill, get BGA chip x-rays done to know the bga solder joints weren't corroded.
这个答案有帮助吗?
得分 2
2条评论:
Great suggestion on the rice ;-)
完成的
I try my best
完成的
添加一条评论
添加你的答案
Dyords 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 23
总计 344
