跳转到主内容
加入维修社区 - 创建账户
型号 A1419 / EMC 2806 / 2014 年末或 2015 年中期。3.3 或 3.5 GHz Core i5 或 4.0 GHz Core i7 (ID iMac15,1);EMC 2834 2015 年末 / 3.3 或 3.5 GHz Core i5 或 4.0 GHz Core i7 (iMac17,1)。均配备 Retina 5K 显示屏
Upgrading Processor on Late 2015 iMac 27
Late 2015 iMac 27 Retina 5k
I have two iMac 27's. One has an an Intel Core i7 processor.
The other one has an Intel Core i5 processor.
The speed difference is noticeable, so I'd like to upgrade the i5 to an i7 processor. Can someone please give me the i7 processor model number?
Can it be swapped plug & play, with no other concerns?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 8
4条评论
Thanks. I already scanned that process. It's the easy part.
That didn't address my original question.
完成的
Processor Name: Intel Core i7 6700K
Processor Speed: 4 GHz
Number of Processors: 1
Total Number of Cores: 4
L2 Cache (per Core): 256 KB
L3 Cache: 8 MB
This is the processor that i have already use.
完成的
I'm having an issue with the i5 logic board as well. My question is the video card a part of the logic board?
完成的
Hi yes it is a part of the Logic Board.
完成的
添加一条评论
5个答案
已选择的解决方案
It’s still working the best. No problems at all. I use it daily.
这个答案有帮助吗?
得分 3
1条评论:
thx a bunch! I was weary about the tdp rating being nearly 30 watts higher
完成的
添加一条评论
最有帮助的答案
Hi!
I have just upload a video in Youtube for the imac 27" Late 2015 CPU Update.
I try both i7-7700K and the i7-6700K.
I have desassembly ans asasseble the iMac 7 times! :)
The i7-7700K will NOT WORK!!!
The i7-6700K WORKS Fine!!! Very smooth...
Operation Temps: 40-55 idle, and 85-99 (Rendering).
Very happy for updating the CPU ( I had the i5-5600 3.2Ghz)
这个答案有帮助吗?
得分 18
21条评论:
Thank you for your info. You saved me a lot of time.
完成的
You are welcome!
完成的
Hey i have the same problem i also buy i7 7700k and it doesn't work with my late 2015 27 iMac. and i also deassembly and assemble it 8 times as well :D
So now i need to buy 6700 or 6700 k ?
完成的
I used the i7-6700K, and it works fine! the i7-7700k will NOT work....
完成的
I also have the same imac, and I plan to migrate from core i5 to i7. Thanks for the help!
完成的
显示更多的16条评论
添加一条评论
Here's the guide for doing it: iMac Intel 27 英寸 Retina 5K 显示屏 CPU 更换
UPDATE
The iMac "Core i7" 4.0 27-Inch Aluminum (Retina 5K, Late 2015/Skylake) features a 14-nm "Skylake" Quad Core 4.0 GHz Intel "Core i7" processor (6700K) with four independent processor "cores" on a single chip, an 8 MB shared level 3 cache, 8 GB of 1867 MHz LPDDR3 SDRAM (PC3-14900) installed in pairs (two 4 GB modules)
4.0 GHz Core i7 (I7-6700K)
http://www.anandtech.com/show/9483/intel...
这个答案有帮助吗?
得分 9
8条评论:
I am wondering if someone has tried upgrading this model to 7700k (kaby lake). Since the socket connection is the same. I don't see a reason why it wouldn't work (apart from EFI or some other safety checks).
完成的
Its more than the socket its also the PCH needs to support it and the systems firmware as you noted needs to handle it.
I'm not sure if given the amount of work and the risks in replacing the chip are worth it given the slight speed bump you would get.
完成的
Would this clear this question?
SnazzyLab dit it in this video.
https://www.youtube.com/watch?v=knMM9dRw...
完成的
taogde Nice video! I invited him to join us.
完成的
SnazzyLab did upgrade iMac 2017 not 2015 !
完成的
显示更多的3条评论
添加一条评论
Hey guys, do I need to install new OS after change CPU? For windows OS, I know we have to but not sure for
这个答案有帮助吗?
得分 0
3条评论:
Not for macOS
完成的
No as Dan said.
But in my opinion if you have other problems on the macOS is good after some years to make a new "clean" installtion. :)
完成的
When do you have to reinstall for Windows?
完成的
添加一条评论
Guys, have you ever tried to put the CPU from the 2017 in the 2015? It is the same socket! Could probably have the support because the 2017 iMac already use it! Any comments?
这个答案有帮助吗?
得分 0
2条评论:
Emanuel, George Siorios tried putting an i7 7700K and it does not work. It will work only with 6th gen CPUs. The i7 6700K being the best you can put on it, for the Late 2015 models.
完成的
Hi to all.
yes, the socket maybe is the same but the CPU is NOT working..
完成的
添加一条评论
添加你的答案
clearw 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 16
过去 30 天: 75
总计 48,373
