跳转到主内容
加入维修社区 - 创建账户
型号 M8407 / 550 或 667 MHz G4 处理器
How do you fix the Clock reset problem?
I need to reset the clock after each power-down.
I am sure I need a pram battery, just not sure which one:
The 3v lith coin cell, or the:
The G4 Titanium Mercury PRAM Battery @ $39.95
Product code: IF121-017-1
Apple Part #: 922-436
Do I need to open up the case to see which one?
Thank you.
DC
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Your PRAM battery needs to be replaced. It appears to be part number 922-5205 for the PB G4/DVI 667. Here's Apple's guide on which battery you need: http://support.apple.com/kb/ht2295
这个答案有帮助吗?
得分 2
添加一条评论
You must know
the exact specifications of your PowerBook.
PowerBook G4 (15-inch FW800) & PowerBook G4 (15-inch 1.5/1.33GHz) 922-6007
PowerBook G4 (15-inch 1.67/1.5GHz) 922-6714
Powerbook G4 (15-inch Double-Layer SD) 922-7173
Remember to return and mark accepted the answer that best solves your problem.
Good luck,
N
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Crocdog 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 14
总计 1,941
