跳转到主内容
Business-grade laptop released in 2009. Model Number: Latitude E5500.
13 个问题 查看全部
What could be causing loud fans?
The fans in the computer are making loud noises that it never had before. Even when the computer is running something simple, like a web browser, the fans are making noise.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
If I could give a one word answer it would be dust. Dust throws the fan out of balance and causes it to make more noise than usual it also decreases the cooling efficiency of the computer so the fan runs harder for longer .To clean it you can do it one of two ways . one is to take the computer apart and physically clean the fan this will yield the best result . Or you can by a can of compressed air from your local computer store and blow air through the vents both ways works best one way for a while then through the exhaust. If you have access to an air compressor you can use that as well as long as you dont hit it with too much pressure. Hope this helps
这个答案有帮助吗?
得分 2
2条评论:
another wasted answer
完成的
It worked for me, thank you!
完成的
添加一条评论
The most common cause of this issue is dirt and dust making it's way into the fan and venting system of the device. The best way to be completely take care of this problem would be to take apart your device and clean it by hand. Once you've cleaned your vent and fan system, put the device back together as before and your problem should be solved.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Ryan Dionne 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 30
总计 2,189
