跳转到主内容
The Alcatel One Touch Pop 7 is a tablet that was released in February of 2014. It is identified by the model number P310A or P310X.
Why isn't my device charging?
My tablet is not charging even though it is connected to both the wall and the tablet. I always charge it before I go to bed from the same outlet and it was charging properly until last night. What could be the problem?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Switch the charger to a different outlet to start with. If this doesn't work perform a soft reset on the tablet. This is done by holding the power button for 3-5 seconds. More than likely this will solve the problem, but if it doesn't try using a different micro USB charger. If none of these have worked, the battery is the problem. Unfortunately we haven't found an effective and reliable way to remove the battery. Check out our Troubleshooting Guide.
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
I had the same problem!
Holding the Power Button DID work. However, it took about 12 seconds for it to power on.
Once it powered on, it shows that the battery is at 96%
It's always been on the same charger at night when I go to bed.
Will try the same charger again tonight. If it was a “fluke" then GREAT!
If not then will try different charger/outlet tomorrow. Will update!
P.S. I also have an ONN TV which experiences periodic static charges which causes volume changes. It needs to be unplugged for a minute (or so)…
Once plugged back in, it works perfectly!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Kayla Maus 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 19
总计 11,360
