跳转到主内容
The Toshiba Satellite L305D-S5895 is a Laptop that was released by Toshiba in 2008.
What happens if one of my keys is not working?
The rest of the keyboard is working fine, but one of my keys seems to be stuck in place.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
最有帮助的答案
You can pop it off, by gently prying from underneath the key. There may be something underneath the key making it stuck. To put it back on, just line up the hinge to the clips on the underside of the key. Otherwise, just replace the keyboard, they cost about $10-20 , and they're easy to replace.
这个答案有帮助吗?
得分 1
添加一条评论
First remove the key that isn't working and search for debris under where they key was. Next clean that spot thorough so thats their is nothing blocking the key from fitting in its respective spot and clean the key before replacing. If the key isn't the problem and it is still not working properly replace the keyboard or bring it to your local repair store.
这个答案有帮助吗?
得分 0
添加一条评论
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Daniel Matheson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 171
