跳转到主内容
12.1" business laptop released in June 2012 by Lenovo. This laptop uses multiple product numbers, which vary based on configuration.
Why isn’t my Thinkpad charging?
The Thinkpad is properly plugged in at both ports but is not building a charge at all.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
student question
完成的
添加一条评论
2个答案
最有帮助的答案
Test the power cord with a multimeter like in this guide.
Testing Power Cord Continuity
Then I would also test the power adapter is it is working with the multimeter
如何使用万用表
If both test work fine then you know that your power adapter is fine and working.
You should also look at the power connector on he laptop so it is not loose because then the soldering might not lead the electricity. Good lock in testing.
Electrical图片
指南
难度:
非常容易
1 - 5 minutes
Electronics Skills图片
指南
如何使用万用表
难度:
简单
5 minutes
这个答案有帮助吗?
得分 2
添加一条评论
Try replacing the battery or buying a new charger.
这个答案有帮助吗?
得分 0
1条评论:
Try pressing and holding down the power button for 3 - 4 seconds with the battery removed. Then try putting the battery back in, along with the AC adapter and see if it will charge. If this does not work try updating your motherboard.
If none of this works then try purchasing a new battery and AC adapter.
完成的
添加一条评论
添加你的答案
Lino Virgen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 408
