跳转到主内容
加入维修社区 - 创建账户
2012 年发布的 8 英寸安卓平板电脑。该设备配备 1 GB 内存和四核处理器,最高支持 16 GB 存储。8 英寸 LCD 显示屏分辨率为 1280x800,采用 IPS 面板,并支持电容式多点触控。
Device screen dose not respond
I have a digital d2 tablet and the screen dose not respond when i touch it. Can you give me some possibilities on how to fix this problem?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
device will not turn on
由完成的
Hi @elkarch5 ,
Have you tried starting it with the charger connected, you didn't say?
Does it give any indications on the screen when you first connect the charger to it and switch the charger on?
由完成的
添加一条评论
2个答案
已选择的解决方案
Have you tried restarting the device? That usually fixes the issue. If that does not help, try playing with the volume. If the volume works, then the touch sensor may have gone bad.
这个答案有帮助吗?
得分 0
1条评论:
Mine's screen doesn't work after restarting it. Its also broken with a crack on it. Is there anyway to get a replacement to to fix it?
由完成的
添加一条评论
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dalton Berg 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 20
总计 679
