Device screen dose not respond
I have a digital d2 tablet and the screen dose not respond when i touch it. Can you give me some possibilities on how to fix this problem?
Have you tried restarting the device? That usually fixes the issue. If that does not help, try playing with the volume. If the volume works, then the touch sensor may have gone bad.
这个答案有帮助吗?
Mine's screen doesn't work after restarting it. Its also broken with a crack on it. Is there anyway to get a replacement to to fix it?
这个答案有帮助吗?
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 5
总计 331
2条评论
device will not turn on
由 Edward L Kuykendall 完成的
Hi @elkarch5 ,
Have you tried starting it with the charger connected, you didn't say?
Does it give any indications on the screen when you first connect the charger to it and switch the charger on?
由 jayeff 完成的
